Orbiter 2 Clockwork 2 Mods?
BeepDog
I'm looking to mount my shiny new orbiter2 on a Stealthburner. I have also purchased their filament runout sensor, as it's pretty amazing in theory, so I was gonna give it a shot. I've only been able to find these 3 mods:
- https://github.com/sneakytreesnake/StealthOrbiter
- https://www.teamfdm.com/files/file/485-orbiter-2-clockwork-beta/?tab=details
- https://github.com/elcrni/Voron-Mods/tree/main/Orbiter_2.0_SB_CW2_Enclosed -- Won't work with the filament runout sensor, because it boxes it in. Might also not work with a toolhead PCB.
Does anyone know of any other clockwork2 mounting things?
I think I'm gonna have to get creative with the toolhead PCB, as the lever for the orbiter is on the "wrong" side (I think?)
Anyone out there got any tricks up their sleeves, or other mods they've found?
I was just about to investigate the same thing since my CW2 just failed me. If I find anything useful I will post it here.
To follow up on some things, I'm using the one from here: https://github.com/elcrni/Voron-Mods/tree/main/Orbiter_2.0_SB_CW2_Enclosed
It works fine with a single piece toolhead PCB, but there isn't enough room between the extruder and the fan for the two part PCB, as the Orbiter 2 sits forward a bit more than the Clockwork does.
I don't have the filament runout sensor attached, sadly.
It's printing fantastic, however. The prints look great and so does the printer.
Hi I 'm looking to install orbiter 2.0 in SB as well, however, do you come across any mods that support 2-pcs board? I have a SB2040 CAN toolboard installed on CW2 for now. Looking to change into Orbiter 2.0 instead of replacing with Bondtech toothed gear 😅.
I have not found one that works with the two part PCB. The orbiter sits a bit further forward, so it doesn't leave enough space.
How did you get the part cooling fan (the top one) to fit with the Orbiter? I need an additional 2-3mm space for the main body to close nicely against the rear body. But I don't seem to find out how.
Maybe that depends on the vendor of the part cooling fan?
I'm using a GSDTime fan, and it fit just fine.
You could try sanding down the edges of the case a bit to see if it's catching on the stealthburner face, maybe it just needs to scoot in a bit more.
For the whole model, the designer is a "tolerances are for weanies" kind of engineer :) - with all parts perfect it does indeed fit. Thanks for your suggestion. I'm now tuning.
