StreetSports
Here we go. I have it set to, when there is no mesh or z offset saved already, first it taps the nozzle to the bed a few times via beacon contact, moves the sensor over the area that was tapped by the nozzle, moves the nozzle to the correct offset, measure with the beacon non contact sensor, saves the correct z offset for the nozzle so that all scans will now be touchless, measures the corners, does quad gantry leveling, checks its work and then goes into the 15x15 bed scan twice(turned it down from 25x25. Oh and first it does sensorless homing.
