MichaelOToole
Decided to build a second 2.4 (350mm) using Kits from chaoticlab's as they supply everything in individual kits.
My main aim here is to evaluate this approach and provide feedback on the kits/process so that others may gain from my experience.
I will post prices later in the post, so far it looks like it will cost less than my first build using LDO Kit & Chaoticlab CNC Parts...
These are the kits available:
[Set 1] Electronics Kit (this kit is no longer available, parts sourced separately)
[Set 2] Full Cable Kit
Chaoticlab black box, quality excellent, perfect packaging, looking good...
[Set 3 ]Full Fastener Kit
TBA
[Set 4] Heated Bed Kit
Chaoticlab black box, quality excellent...
Contents: Bed 8mm, Heater (240VAC), Spring Steel (textured both sides), Adhesive Magnet Sheet...
Notes: You will need high temperature silicone adhesive to bond heater to bed... I need to source this, any ideas?
[Set 5] Motion Kit
Chaoticlab black box, perfect packaging...
Excellent quality (perfect)...
[Set 6] Panels Kit
TBA
[Set 7] Frame Kit
Chaoticlab black box, perfect packaging, mint condition extrusions, nice din rails...
CNC Kits:
CNC Parts Kit V2.0 (should have ordered the kit with the CNC Tap included) oops..
Excellent quality (mint), perfect packaging...
Awaiting other CNC kit delivery:
CNC Voron Tap V2.0
CNC Door Mounting Kit
Costs:
Not going to price in the printed parts as I have lots of filament and will print them myself...
Allow about $100 for Stealthburner and associated parts...
Notes on prices:
Some parts are less expensive now (two years later) such as the CNC kit, this can account for some of the saving plus less printed parts bought.
I had hoped for some saving and it's looking like there is at least $300, but I have probably missed something.
Would be happy if €1500 is achievable for a genuine all metal build.
Conclusion:
Although everything looks perfect on inspection, If all the kits match the quality of the chaoticlab's CNC kit, I will be over the moon...
I can't start the build yet, have to make room for it and wait for the fasteners etc...
Updated: 7th Jan 2026
Electronics Kit no longer available, sourced items elsewhere, details above update...
Mike
- Voron 2.4 Electronics Kit (Set 1 - $295) Out of stock & Discontinued
- Voron 2.4 Full Cable Kit (Set 2 - $45)
- Voron 2.4 Full Fastener Kit (Set 3 - $56)
- Voron 2.4 Heated Bed Kit (Set 4 - $129)
- Voron 2.4 Motion Kit (Set 5 - $229)
- Voron 2.4 Panels Kit (Set 6 - $109)
- Voron 2.4 Frame Kit (Set 7 - $109)
- Voron 2.4 CNC Parts Kit V2.0 ($399 no tap)
- Voron 2.4 Tap V2 ($44.99)
- CNC Voron Tap Sensor V2 Module ($15.99)
- Kraken V1.1 (€101.75) biqu...
- LDO Motor Kit (€109.02) biqu...
- Pi TFT50 V2.1 display (€32.13) biqu...
- Meanwell LRS-350-24, RS-25-5 (€60.63) Aliexpress...
- Omron G3NB-210B-1 10A (€19) Aliexpress...
TBA
[Set 5] Motion Kit
[Set 6] Panels Kit
TBA
[Set 7] Frame Kit
CNC Kits:
CNC Voron Tap V2.0
Costs:
From memory I believe I spent about €1650 (possible a little more).
Current Build:
Approximately (€1250)
Notes on prices:
Conclusion:
Mike
