- Voron 2.4 300mm
- Clockwork 2
I am having problems with my freshly built Voron 2.4(LDO 300 mm kit). I always end up with too much squish at the front of the bed and not enough squish at the rear of the bed. Feels like I have tried every different bed_mesh setting. I am using a klicky probe and I don't think it has anything to do with accuracy as I have tested the accuracy and the mesh is constantly wrong. My average bed variance while printing ABS at 100 c is 0.12.
This is my current config:
picture of prints:
The config above has given me the best results I have achieved yet(picture above) I am currently using this along with the standard klicky bed mesh macro(https://github.com/jlas1/Klicky-Probe/blob/main/Klipper_macros/klicky-bed-mesh-calibrate.cfg)
As you can see from the pictures, I have too much squish at the front of the bed and not enough squish at the rear of the bed. I have considered the Y distance of 25-30mm between the nozzle tip and Klicky switch, and believe it to be the underlying cause of my problems. Nevertheless, I am unsure of how to rectify the situation, and I am optimistic that a software solution may exist. Surely, I cannot be the sole individual grappling with this issue.
[bed_mesh]
speed: 400
horizontal_move_z: 7.5
mesh_min: 40, 40
mesh_max: 260,260
fade_start: 1
fade_end: 10.0
probe_count: 9,9
bicubic_tension: 0.2
algorithm: bicubic
relative_reference_index: 40
move_check_distance: 3
split_delta_z: 0.01
mesh_pps: 3,3
picture of prints:
