- Voron 2.4 350
- Clockwork 2
Hi All,
I recently built my first Voron and all has gone pretty well apart from an issue I am having with the touch screen which I cannot seem to rotate.
After following LDO's documentation for rotating the screen (link below), It will not boot into Klipper and just hangs on a black screen until I revert the settings back to default
It does mention to hash out dtoverlay=vc4-fkms-v3d which I didn't have but I do have dtoverlay=vc4-kms-v3d which I hashed out but that didn't work either.
Here is my config:
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
#disable_fw_kms_setup=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[all]
display_lcd_rotate=2
dtoverlay=rpi-ft5406,touchscreen-inverted-x=1,touchscreen-inverted-y=1
I've heard mentions that it may be due to me using a Raspberry Pi 3 but not sure if that is true or not.
Any ideas?
Thanks in advance
oOMezzaOo
Touchscreen Setup for Klipper
docs.ldomotors.com
Here is my config:
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
auto_initramfs=1
max_framebuffers=2
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
[all]
Any ideas?
Thanks in advance
oOMezzaOo
