this is my first time building a voron and first for canbus and im fairly new to klipper within the last 6 months. i built the Formbot 2.4 pro and have all my errors solved except the external thermistor on the ebb 2209. i have a pt100 and it doesn't matter what i do it reads in the negative and no response to temp. i have change sensor type in config, i tried switching from 2 pin to 4 pin port and back again, tried every dip switch setting and have tried 2 different thermistors and still no luck. i would really appreciate a helping hand for this noob
THIS IS SB2209.CFG
# This file contains common pin mappings for the BIGTREETECH EBBCan
# Canbus board. To use this config, the firmware should be compiled for the
# RP2040 with "USB" or "CAN bus (on gpio4/gpio5)".
# The "EBB Can" micro-controller will be used to control the components on the nozzle.
# See docs/Config_Reference.md for a description of parameters.
[mcu EBBCan]
canbus_uuid: 524ba661ff18
[temperature_sensor EBB_NTC]
sensor_type: Generic 3950
sensor_pin: EBBCan:gpio28
[adxl345]
cs_pin: EBBCan:gpio1
spi_software_sclk_pin: EBBCan:gpio2
spi_software_mosi_pin: EBBCan:gpio0
spi_software_miso_pin: EBBCan:gpio3
axes_map: z,-y,x
[resonance_tester]
probe_points: 100, 100, 20
accel_chip: adxl345
[extruder]
step_pin: EBBCan:gpio18
dir_pin: !EBBCan:gpio19
enable_pin: !EBBCan:gpio17
microsteps: 16
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: EBBCan:gpio7
sensor_type: Generic 3950 #ATC Semitec 104GT-2 #EPCOS 100K B57560G104F #Generic 3950
sensor_pin: EBBCan:gpio27
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp:-100
max_temp: 300
# sensor_type: MAX31865
# sensor_pin: EBBCan:gpio9
# spi_software_sclk_pin: EBBCan:gpio10
# spi_software_mosi_pin: EBBCan:gpio8
# spi_software_miso_pin: EBBCan:gpio11
# rtd_nominal_r: 100
# rtd_reference_r: 430
# rtd_num_of_wires: 2
[tmc2209 extruder]
uart_pin: EBBCan:gpio20
run_current: 0.650
stealthchop_threshold: 999999
[fan]
pin: EBBCan:gpio13
[heater_fan hotend_fan]
pin: EBBCan:gpio14
heater: extruder
heater_temp: 50.0
[fan_generic 4W_FAN0]
pin: EBBCan:gpio15
tachometer_pin: EBBCan:gpio12
#tachometer_ppr: 1
[neopixel hotend_rgb]
pin: EBBCan:gpio16
#[bltouch]
#sensor_pin: ^EBBCan:gpio21
#control_pin: EBBCan:gpio22
[probe]
## Inductive Probe
## This probe is not used for Z height, only Quad Gantry Leveling
## NPN and PNP proximity switch types can be set by jumper
pin: PF1 #M4-STOP
x_offset: 0
y_offset: 25.0
z_offset: 0
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
#[probe]
#pin: ^EBBCan:gpio6
THIS IS SB2209.CFG
[mcu EBBCan]
[adxl345]
axes_map: z,-y,x
[resonance_tester]
accel_chip: adxl345
[extruder]
microsteps: 16
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp:-100
max_temp: 300
[tmc2209 extruder]
run_current: 0.650
[fan]
pin: EBBCan:gpio13
pin: EBBCan:gpio14
heater: extruder
heater_temp: 50.0
pin: EBBCan:gpio15
#tachometer_ppr: 1
pin: EBBCan:gpio16
#[bltouch]
[probe]
## Inductive Probe
pin: PF1 #M4-STOP
x_offset: 0
y_offset: 25.0
z_offset: 0
speed: 10.0
samples: 3
#[probe]
#pin: ^EBBCan:gpio6
