thespacecowboy
My LDO kit has a frame grounding wire, but I struggle to find where in the documentation this is mentioned. It talks about connecting it to the wiring, but never the frame.
This is an anodized blue frame, will trying to ground it even work or would every extrusion need a ground?
Want to make sure I do the right thing here... the only thing that seems to be mentioned in the Voron 2.4 manual is the bed earth.
thank you
thank you
