Question Logitech C270 webcam not working on printer, works on PC
xark
Trident
Anyone else got problems with Logitech C270 webcam not working on LDO Voron Trident RevD? I use RPi3B+, with Nitehawk connected thru USB on RPi, same with Leviathan board and USB thumb drive for RPi OS. When I connect webcam, RPi does not want to boot. If i connect it after bootup, it isn't show in lsusb command. If I have only webcam connected, it works. I know it is probably a power issue. I just need to know how others solve similar problems, because I tried powered USB hub and it still didn't work.
Thank you.
It is a known issue. The combination of this webcam and Rpi gives problems. You have to use a modified bootcode on a SD card. Then booting from the SD card.
I am still new here, so I will be careful with sharing links. But you will find the modified bootcode on github.
Is this problem only for this camera or any other too, if by any chance you know? I would rather stay on booting from USB rather than SD card.
Thank you for the info;)
I have seen the same issue with other cameras like the pro 9000 and C525, so I am afraid it is your RPi.
But you have a specific slot for RPi cameras, so I would get a cheap RPi camera and print your own mount :)
I found the bootcode.bin and even that did not help. As you said it is probably my RPi. And thanks for the idea. I would never think to buy RPi camera, was looking for buying some new webcam from Aliex and being scared if i would waste money away or not:p. I hope at least RPi came will work:)
you can find cheap RPi cam on ali as well.
advantage of RPi camera is the speed, much faster, very good for livestream.
