Question Max temp for LDO Nitehawk-SB?
xark
Trident
What is the max working temperature of LDO Nitehawk-SB board? I am reaching chamber temperatures of ~73˚C and Nitehawk-SB at ~90˚C while printing with ASA and using my "blanket-over-my-voron" mod:p. Should I lower my chamber temps or install some fan on the Stealthburner to blow on the NH board?
Have you crashed yours yet? Mines pushing past 80 deg C now I am getting my chamber temps up.
Any cooling fan options for it that you know of?
I had all kinds of trouble before I put the fan. Running temperature was around 78C with random errors. When it hits 80C, it killed the power to the hotend, or the severe under extrusion causing nozzle clog. I put the fan on, now it runs at around 57C. No problem so far. We will see. IF you are planning on installing the Nitehawk-SB, install the fan along with it. There are wire cover mod with fan on.
