MCU 'can0' shutdown: Missed scheduling of next digital out event
Martin17017
Voron 2.4
Hi everyone,
I'm having an issue with my Voron 2.4 build and could really use some help:
Specs:
  • 350mm
  • Stealthburner with EBB36 V1.2
  • BTT U2C v2.1
  • Klicky PCB probe
  • Octopus V1.1
  • Raspberry Pi 3B
  • Mainsail
The problem: Whenever I start a print, I often get this error:"MCU 'can0' shutdown: Missed scheduling of next digital out event."
I feel like I've tried everything. I replaced the USB-A to USB-C cable with a shielded one between the Pi and the U2C, but it didn’t help.
Now the printer won’t start unless I power it off and on again. I’m stuck and not sure what to try next.
If I’ve missed any relevant details, just let me know and I’ll provide them.
Thanks in advance for any help!
It might be buffer size issue (at least mine was)...
ssh into your Pi setup...
Run: ifconfig in console and check txqueuelen in can0: section
Should be something like: txqueuelen 128
My issue was it always defaulted to: txqueuelen 10 on startup/boot (I think this has been fixed since).
I use a Pi 3...
If the value is too low, it will result in timeouts. I don't think it happened since I updated, it now uses 128 but if it does, I'll try: sudo ip link set can0 txqueuelen 512
See this post for more info
