cadler
Hello, I started some time ago to build a Voron 2.4. Now I finished the wiring. Everything went well. Connection to the Pi, serial number from the octopus... Bed and extruder heating like described in video. During the Stepper Motor Test I realised, that the Z1 Motor and the Extruder Motor did not react. After changing the plug of the Z1 Motor to the Z socket the 1mm movement started. So I tried to disconnect and change the stepper drivers. Maybe there went something wrong. Now I can not connect from Moonraker to the klipper software. How can I check / fix this issue. Or did I damage something on the octopus board by removing the stepper driver. Thanks for any help.
