Laserbea4k43
Voron 2.4
Hi,
Just installed Nitehawk and got the device id and installed the firmware.
I took a deep breath and powered it on. Nothing blew up!! But I still have problems.
Any Ideas? i'm guessing my config file is bad...
OK, PF and HF are now working.
The Faceplate connected so nicely, that I just swore that it was working!
Can't get a combination that will get the LEDs to light up ( they probably won't light up without a data connection anyway), but that's the least of my worries.
Sorry about the mess, when I get started it's like Hurricane Laserbeak in here.
Onto the TAP.
Data and V+ wires needed to be swapped.
I get a red LED with no status change. Broken?
I also commented out the [probe] entry in nitehawk-sb.cfg and set the correct pin in printer.cfg
Ordered a new sensor, just in case. Will be here tomorrow.
- BTT Octopus
- StealthBurner w/ Phateus Rapido
- Tap
- Nevermore Duo
Hi,
- I tested the Part Fan (2 prong - I've commented anything that has 'tacho' in it.) and it didn't turn on, but the LED glows brighter according to the speed increased.
- I tested the TAP probe (bought a CNC TAP to replace my other one) and ran QUEREY_ENDSTOPS and the TAP remains open, no matter what state it's in. No light either.
- SB Lights are off and not adjustable
- I just got brave and set the extruder to 45. It heats up, but the fans don't turn on. The HE Fan LED is on though...
Bash:
me@myvoron24:~/klipper $ make flash FLASH_DEVICE=/dev/serial/by-id/usb-Klipper_rp2040_E6635C469F330E27-if00
Flashing out/klipper.bin to /dev/serial/by-id/usb-Klipper_rp2040_E6635C469F330E27-if00
Entering bootloader on /dev/serial/by-id/usb-Klipper_rp2040_E6635C469F330E27-if00
Device reconnect on /sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3
/usr/bin/python3 lib/canboot/flash_can.py -d /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0 -f out/klipper.bin
Attempting to connect to bootloader
CanBoot Connected
Protocol Version: 1.0.0
Block Size: 64 bytes
Application Start: 0x10004000
MCU type: rp2040
Flashing '/home/me/klipper/out/klipper.bin'...
Write complete: 110 pages
Verifying (block count = 438)...
Verification Complete: SHA = 95FE0505EE1AAAA379F19EB9F3D1209AE427CF22
CAN Flash Success
me@myvoron24:~/klipper $ ls /dev/serial/by-id
usb-Klipper_stm32h723xx_240035001551303531313638-if00
- SB LEDs still not working. Going to check soldering joints
- TAP Still not working. Going to check connections (i just plugged it in stock)
Onto the TAP.
