m00dawg
I'm finding using a skirt as a purge/prime solution doesn't work well for me because at the very start it deposits plastic "pebbles" that are hard to remove and have to be "printed over" in order to remove them (basically combining them with the model I'm printing). This isn't ideal when using different colored filaments. So instead I am using a "purge slab" of sorts that I print in the top right or left in the same place. Some folks don't like this for the potential for wear but I haven't noticed any real issue there and simply don't print over to that corner except under special cases.
The problem with the slab is I'm doing it by adding a box in SuperSlicer but sometimes I forget to make sure to put it at the first object. It's not at all helpful if it prints 3rd since I've already "primed" by printing the first layer of a model.
So what I'd like to do is take the GCODE that prints the box and simply use that as the start GCODE for the printer or filament. I suppose with Klipper I could even use a macro that I just call to keep the start gcode short.
Has anyone done this and have recomendations? Doing it manually is fine except when I forget the order as noted above then it sucks because I have to rub an ice cube on over the primed area to try and get all the plastic bits off.
Hopefully all that made sense
