kharrisma
Hi Forum Folke,
Hammering away at config file errors, post-Nitehawk SB installation and post-update to Klipper and Mainsail. Managed to shoot each one down, untii this one:
For the sake of simplicity and ease of reading the config files, I added an {include nitehawk-sb.cfg} to the beginning of my printer.cfg file... which leaves me with a dilemma: *where* does the information for the heat-block thermistor go? In the printer.cfg, or in the nitehawk-sb.cfg? It's a V6 hot end, which typically uses an ATC Semitec 104NT-4-R025H42G. Klipper accepts this thermistor type, but gives me that error message. Meter across the thermistor at room temp (65F/18C) giving a 4.4MEG ohm reading?? That doesn't seem right; according to the chart, it should be about 139 ohms. Thought it might be a bad thermistor or wiring, so I plugged in a new Winsinn HT-NTC100K from my parts box (meter showed 135 ohms, which is about what the RT chart calls for) and edited the config files accordingly, did a firmware restart... but I *still* get the same message, just with a different temperature:
At a loss for direction at this point. Not sure if the issue is having thermistor data in two config files, or if only one should have them, which one. Need to sleep on this and try again tomorrow, maybe with some ideas from you folks.
