Toohead CT : CMFB103F3950FANT not compiling ?
kiklo
As pr doc. this is my toolhead/ chamber thermistor :
CMFB103F3950FANT​
In our Toolhead PCBs, we use an NTC10K SMT thermistor. The datasheet can be found here.
But it will not compile my printer.cfg. ( and testing with any other; temp is far out - 70C at room temp.
What is the correct setting to use ?
I have tested these :
# Additional Sensors
[temperature_sensor chamber_temp]
## Chamber Temperature - T1
# sensor_type: Generic 3950
# sensor_type: ATC Semitec 104NT-4-R025H42G
# sensor_type: TDK NTCG104LH104JT1
sensor_type: CMFB103F3950FANT
sensor_pin: PF5
min_temp: 0
max_temp: 100
gcode_id: chamber_th
This is kind of a guess, but do you have the definitions for the thermistor in the config file? If I understand it correctly, you need to define the thermistor characteristics before you can use it.
LDO thermistor code:
[thermistor CMFB103F3950FANT]
temperature1: 0.0
resistance1: 32116.0
temperature2: 40.0
resistance2: 5309.0
temperature3: 80.0
resistance3: 1228.0
In theory, if you place that code before your additional sensors section, it should work.
Did the trick.
Not elegant as I just put it in front of my section.
should be in an other file somewhere.
I might find out where later.
Thx again.
