NeoRazZ
i just discovered the floating gantry system of the voron
i think it would solve some of the issues in the design ive been working on for the last few years on and off (mostly off)
original tractor feed green bar printer
this box is full steel
im going to bolt the 2020 extrusion to the side walls
i already have the print bed 23"x23" glass and aluminum sheet with 4 heaters for zone control of temperature
4 x relays direct ac 600w each should also work as chamber heater
i guess my fist question .
if i finished this does it qualify as voron ? like for a serial number
i have 10x 1000mm 2020 pieces
im not so worried about maximum speed
more reliability (MTBF) and accuracy
if this seems like a terrible idea we can put motors under it and turn it into a low rent dalek
