Question Canbus Stealth Changer build X Y limit switch option
saaby95
2.4r2
Hi I am new to Voron forum. But I have built my 0.1, 2.4 and micron over the past few yrs with excellent instruction online.
I have always wanted to try MMU and has successfully build a ERCFv1. But it's so bulky and wasted so much time switching filament I scrapped it just after few print job,
I see the advantage of toolhead change so I wanted to try and build the Stealth Changer, my plan is to build 2-3 dragon burner + galileo2 + ebb36 can toolhead board using Canbus.
However I cannot seems to find any idea where to locate the X and Y limit switch on a multi toolhead system. Where you guy put these switches? I am trying not to use sensorless as I encounter some reliability issue on my V0 with sensorless homing.. My micron is on CANbus but there is only 1 toolhead so its easy, my X is on the X carriage and Y at the A motor.
Any pointers for me how should I place the X and Y limit switch? I am trying to get rid of the Y chain and not go sensor less.
thanks in advance
ck
