PrintMeUpScotty
- Voron 2.4
- Clockwork 2
I am trying to setup sensorless homing on my new Voron 2.4. I was able to get X, but Y wasn't cooperating... turns out the endpoint was triggered. I have checked for the endpoints to be defined in the other configs, but nothing there. I am at a bit of a loss with this one.
Manta M8P 2.0 with CM5, CAN/SB2209, using tap. Here is my Y config:
Y Stepper on Motor2 (A Motor)
[stepper_y]
step_pin: PE2
dir_pin: PE1
enable_pin: !PE4
microsteps: 16
rotation_distance: 40
endstop_pin: tmc2209_stepper_y:virtual_endstop
#^PF3
full_steps_per_rotation:200 #set to 400 for 0.9 degree stepper
position_min: 0
position_endstop: 350
position_max: 350
homing_speed: 80 #Max 100
homing_retract_dist: 0
homing_positive_dir: true
[tmc2209 stepper_y]
uart_pin: PE3
interpolate: True
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
diag_pin: ^PF3
driver_SGTHRS: 255
[stepper_y]
step_pin: PE2
dir_pin: PE1
enable_pin: !PE4
microsteps: 16
#^PF3
position_min: 0
position_max: 350
[tmc2209 stepper_y]
uart_pin: PE3
interpolate: True
run_current: 0.8
diag_pin: ^PF3
driver_SGTHRS: 255
