Built my first voron 2.4, 350mm build platform. Ordered a Siboor kit, with canbus. It took longer to assemble than I expected, but that was partly to do with other work commitments. I would work on it in my spare time. My previous 3D printers have all been delta machines built from all new parts and running either Marlin or Smoothieware. Just to be clear, I am not a programmer, and the only language I am fluent in is English. I learn from reading and trying to make sense of lines of code. Linux is a new language again, different to the arduino code I was use to deciphering when building my delta printers.
Not sure if other members are familiar with the Siboor kit, or if the problem I am experiencing is a generic problem. Basically, the touchscreen on my printer gives me an error (after booting up) 'cannot connect to moonraker'. The kit uses a BTT Pi board and touch screen. The firmware came preloaded on a SD card. I have only made changes on the firmware to suit my machine and to change any motor directions etc.
I am able to log into my printer with mainsail. Have gone through my calibrations checks, QGL, zeroing Z height, and saving this to the board. There were two crashes due to logic directions of A and B motors. Everything else seem to work fine. However, I am not able to use the touch screen. So I gather my problem is this moonraker issue. From the mainsail screen, there is no option to check for updates on Klipper or moonraker. I have read that other users have remedied this error by 'reinstalling the needed .conf files on the SD card. But I am unclear how to do this. I have had little luck finding the required files for my machine build. There was a link for an image file, but after clicking it, I get a message to say the file is no longer available.
I am not sure what files I need to upload here for members to view, so be kind and go slow for me. Thanks in advance
Here's a pic of my screen...
