Can't use Klicky probe as z - endstop
hendr1x
2.4r2
Hello everyone,
My stock z-endtop will not produce consistent readings...or at least I can say, when I have it enabled as a z-endstop my z-offset is +/-.5. I've rebuilt it twice and tried sexbolt mod with no help. I converted my Voron back and forth between using the klicky as a z-probe and not. My latest attempt to fix/utilize the z-endstop failed again...I'm trying to revert back and it now refuses to use klicky as a z-probe. It simply uses the stock one. I followed this guide :
Attached are my configs. I would appreciate any help.
That is the style of switch I used. Do you have a recommendation for a different one? I can't run Probe_accuracy because my machine can't home due to klipper config.
I think I desoldered that switch and soldered a "normal" one on. Same swiches are also used for endstops so I had some laying around.
It looks a bit like this
But you can also buy kits like this.
