Centered Filament Feed Voron 2.4V2 Pro
Dr.Who12
For those of you who have had issues with the filament pulling back on the extruder because of the way it is routed, I modified mine to eliminate that. The standard hole in the rear of the enclosure seemed to put undue stress on my Stealthburner to the point I actually saw it actuate my TAP. I tried several different ideas but this one works. I started with taking the exhaust fan housing into Tinkercad and sliced out the threaded portion of the pneumatic fitting (we use these all over the escape rooms and haunted house I work at). Then I adapted tabs to it with holes for screws and I made two different bottom pieces, one for just running a screw into and another that will accept a heat insert. Drilled the center hole the size of the pneumatic fitting in the center of the top of the enclosure and then two smaller ones for the screws. Used some spare M3X16 screws left over from my build and put it together. I didn't put a tube in the fitting yet, I want to see how it performs like it is although eventually I will because of the metal collar inside the fitting.
