Octopus pro v1.1 failed to connect to orange pi 3 lts
panzarik
Hi guys, I'm writing from Kazakhstan, so I have to use a translator.
I ran into such a problem that I can't flash my octopus pro 1.1. As a host, I use orange pi 3 lts with Ubuntu server. It turned out that I flashed the board using a video from Dr.Klipper. But after updating the Klipper itself, octopus stopped being displayed in the system.
After that, I tried clearing all the files and repeating the steps in the video, but they didn't work. I also encountered the problem that Octopus was receiving power from the Orange Pi but wasn't transmitting data. Following advice from a Russian forum, I bought an ST-Link for direct communication with the processor. However, after completely clearing the flash memory of all old files, it didn't work. Before that, I installed the Catapult bootloader following Dr. Clipper's advice. But after deleting all the old files using ST-Link and loading the stock bootloader from GitHub, the problem persisted. As a result, I now only have Octopus with the stock bootloader and no ability to connect to the host. The command "lsusb" doesn't display anything.
After trying everything, I lost hope of successfully building my printer. I read and used a lot of information online and on Russian forums, but unfortunately, nothing helped. And this forum is my last hope.
I don't speak English very well, so I couldn't figure out what topic to post about. Please forgive me.
Hey there!
I would recommend using this side as a guide:
https://usb.esoterical.online/ and follow the steps outlined there.
First thing to check: Does the Octopus still appear via lsusb when in dfu mode?
If yes nothing bad happened yet :)
You might have selected the wrong chip when flashing katapult/klipper.
If you reference the site from above there are various versions of the octopus (including the pro version) outlined here: https://usb.esoterical.online/hardware_config/STM32/BTT_Octopus.html
Double check the stm32 chip version you have on your board and use the settings according to your chip version.
Hey there!
Hello! I put a jumper on BUT0 and connected it to the Orange Pi, but even then, nothing happens and the octopus isn't displayed. Thank you very much, I'll definitely take the links you sent me into consideration and try them out.
Also, after contacting ChatGpt, he wrote that the controller might not boot due to the complete deletion of all data. Specifically, from address 0x0800... I don't know how true this is. I'd also like to point out that during the firmware update, one red LED was constantly blinking, but now nothing is blinking. There was also a beeping sound when turning off, which is also now absent...
