DanielVoronNoob
I am working through merging the Voron 2.4 example config with the M8P v.2.0 and EBB SB2209 CAN(RP2040) sample config. This is a Formbot kit with Moons motors, When plugging things in, I used the pins and ports recommended in the documentation for each component.
If anyone can link to their working printer config for a similar setup, it would help loads. The main thing is the motors and stepper but in case it is relevant, here is my full build:
Formbot Voron 2.4r2 350 kit as a baseline
Manta M8P v2.0 with CB1
No USB to CAN bridges like U2C
Clockwork 2 Extruder in Stealthburner
Physical switch X and Y-endstops
Official Tap as Z-endstop
V6 Hotend and 2 Wire PT1000 temp sensor
Many thanks in advance if anyone has a better starting point than the raw samples for this.
