EBB SB2209 CAN V1.0 (RP2040) + Voron Tap = Only during homing Z axis stepper Z3 goes in wrong direction
Majke
# Z Stepper Settings
## Z0 Stepper - Front Left on MOTOR3_A
[stepper_z]
step_pin: PD7
dir_pin: PD6
enable_pin: !PF10
rotation_distance: 40
gear_ratio: 80:16
microsteps: 16
## Uncomment below for 350mm build
position_max: 340
position_min: -5
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PF9
interpolate: true
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
## Z1 Stepper - Rear Left on Motor5
[stepper_z1]
step_pin: PD3
dir_pin: !PD2
enable_pin: !PD5
gear_ratio: 80:16
microsteps: 16
[tmc2209 stepper_z1]
uart_pin: PD4
interpolate: true
run_current: 0.8
## Z2 Stepper - Rear Right on Motor6
[stepper_z2]
step_pin: PC9
dir_pin: PC8
enable_pin: !PD1
gear_ratio: 80:16
microsteps: 16
[tmc2209 stepper_z2]
uart_pin: PD0
interpolate: true
run_current: 0.8
## Z3 Stepper - Front Right on Motor7
[stepper_z3]
step_pin: PA10
dir_pin: !PD15
enable_pin: !PA15
gear_ratio: 80:16
microsteps: 16
[tmc2209 stepper_z3]
uart_pin: PF8
interpolate: true
run_current: 0.8
# Extruder
## Probe
[probe]
pin: ^EBBCan:gpio22
x_offset: 0
y_offset: 0
z_offset: 0
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
activate_gcode:
{% set PROBE_TEMP = 150 %}
M109 S{ PROBE_TEMP }
{% else %}
{% endif %}
{% endif %}
# Fan Control
# LED Control
#[output_pin caselight]
# Chamber Lighting - HE2 Connector (Optional)
#pin: PB6
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
# Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
## XY Location of the Z Endstop Switch
## Update -10,-10 to the XY coordinates of your endstop pin
## (such as 157,305) after going through Z Endstop Pin
## Location Definition step.
home_xy_position:175,175
speed:100
z_hop:10
[quad_gantry_level]
## Use QUAD_GANTRY_LEVEL to level a gantry.
## Min & Max gantry corners - measure from nozzle at MIN (0,0) and
## MAX (250, 250), (300,300), or (350,350) depending on your printer size
## to respective belt positions
## Gantry Corners for 250mm Build
## Gantry Corners for 350mm Build
## Uncomment for 350mm build
gantry_corners:
-60,-10
410,420
# Probe points
50,25
50,275
300,275
300,25
speed: 100
horizontal_move_z: 10
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
[board_pins]
aliases:
# EXP1 header
EXP1_1=PE9, EXP1_2=PE10,
EXP1_3=PE11, EXP1_4=PE12,
EXP1_5=PE13, EXP1_6=PE14, # Slot in the socket on this side
EXP1_7=PE15, EXP1_8=PB10,
EXP1_9=<GND>, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PB14, EXP2_2=PB13,
EXP2_3=PF7, EXP2_4=PB12,
EXP2_5=PE7, EXP2_6=PB11, # Slot in the socket on this side
EXP2_7=PE8, EXP2_8=<RST>,
EXP2_9=<GND>, EXP2_10=PC5
# See the sample-lcd.cfg file for definitions of common LCD displays.
# Displays
## Uncomment the display that you have
#[display]
## RepRapDiscount 128x64 Full Graphic Smart Controller
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#encoder_pins: ^EXP2_5, ^EXP2_3
#click_pin: ^!EXP1_2
#[output_pin beeper]
#pin: EXP1_1
# Macros
[gcode_macro G32]
gcode:
BED_MESH_CLEAR
G28
QUAD_GANTRY_LEVEL
G28
## Uncomment for for your size printer:
## Uncomment for 250mm build
#G0 X125 Y125 Z30 F3600
## Uncomment for 300 build
#G0 X150 Y150 Z30 F3600
#G0 X175 Y175 Z30 F3600
[gcode_macro PRINT_START]
# Use PRINT_START for the slicer starting script - please customise for your slicer of choice
gcode:
G32 ; home all axes
G1 Z20 F3000 ; move nozzle away from bed
[gcode_macro PRINT_END]
# Use PRINT_END for the slicer ending script - please customise for your slicer of choice
gcode:
SAVE_GCODE_STATE NAME=STATE_PRINT_END
M400 ; wait for buffer to clear
G92 E0 ; zero the extruder
G1 E-10.0 F3600 ; retract filament
G91 ; relative positioning
G0 Z1.00 X20.0 Y20.0 F20000 ; move nozzle to remove stringing
TURN_OFF_HEATERS
M107 ; turn off fan
G1 Z2 F3000 ; move nozzle up 2mm
G90 ; absolute positioning
G0 X125 Y250 F3600 ; park nozzle at rear
BED_MESH_CLEAR
# The purpose of the SAVE_GCODE_STATE/RESTORE_GCODE_STATE
# command pair is to restore the printer's coordinate system
# and speed settings since the commands above change them.
# However, to prevent any accidental, unintentional toolhead
# moves when restoring the state, explicitly set MOVE=0.
RESTORE_GCODE_STATE NAME=STATE_PRINT_END MOVE=0
Please help.
Have you tried removing the "!" from the dir_pin?
From the docs,
"If the stepper does not move at all, then verify the “enable_pin” and “step_pin” settings for the stepper. If the stepper motor moves but does not return to its original position then verify the “dir_pin” setting. If the stepper motor oscillates in an incorrect direction, then it generally indicates that the “dir_pin” for the axis needs to be inverted. This is done by adding a ‘!’ to the “dir_pin” in the printer config file (or removing it if one is already there). If the motor moves significantly more or significantly less than one millimeter then verify the rotation_distance setting."
