Electronics compartment cooling fans.
VoronAT
Does anyone know of way of turning on the the 60x20 cooling fans for the electronics compartment when the RPI temperature hits a certain temperature threshold?
The fans work well to cool the compartment and RPI while printing but I'm interested in knowing how to turn them on while the printer is idle. Thanks.
claudermilk
My solution probably isn't the most elegant, but it works.
Python:
[delayed_gcode skirt_fan_boot]
initial_duration: 1.0
gcode:
  {% if printer.print_stats.state|lower != "printing" %}
    SET_FAN_SPEED FAN=controller_fan SPEED=0.5
  {% else %}
    SET_FAN_SPEED FAN=controller_fan SPEED=0.75 #just so I can see if this is getting called
  {% endif %}
  UPDATE_DELAYED_GCODE ID=skirt_fan DURATION=5
# Pi temperature monitoring loop. Check temp every 5 minutes & turn on skirt fans if too hot. Turn off if cool.
[delayed_gcode skirt_fan]
gcode:
    {% if printer['temperature_sensor pi_4_mcu'].temperature >= 50 %}
      SET_FAN_SPEED FAN=controller_fan SPEED=1
    {% elif  printer['temperature_sensor pi_4_mcu'].temperature < 40 %}
    {% endif %}
  {% else %}
  {% endif %}
  UPDATE_DELAYED_GCODE ID=skirt_fan DURATION=300
VoronAT
Python:
gcode:
  {% else %}
  {% endif %}
gcode:
    {% endif %}
  {% else %}
  {% endif %}
Thanks. Is this something you put in printer.cfg? How does it get invoked? Sorry if these are stupid questions, I'm still learning my way around Klipper. Thanks again.
Yezariael
Could you pls share how exactly it is done? Learning to understand Klipper as well :)
VoronAT
Well, I thought I understood what to do but it doesn't work. I 'm not sure what I'm doing wrong. I put the 2 macros into printer.cfg then saved and restarted the firmware. Nothing happens! I even tried to force the fans on by commenting out all the if statements in the skirt_fan macro - still nothing. I'm missing something and I haven't quite figured it out yet. I'll be sure to let know if I make any progress.
VoronAT
Ok. I got it working. I was missing some additional code plus I'm still learning Klipper syntax and how it all connects. This is what I got.
[temperature_sensor raspberry_pi]
sensor_type: temperature_host
min_temp:10
max_temp: 100
[duplicate_pin_override]
pins: PD12 # this is the pin number that controller_fan uses in my printer.cfg
[fan_generic cpu_fans]
pin: PD12
gcode:
SET_FAN_SPEED FAN=cpu_fans SPEED=.5
{% else %}
SET_FAN_SPEED FAN=cpu_fans SPEED=0.75 #just so I can see if this is getting called
{% endif %}
gcode:
{% if printer['temperature_sensor raspberry_pi'].temperature >= 50 %}
SET_FAN_SPEED FAN=cpu_fans SPEED=1
{% elif printer['temperature_sensor raspberry_pi'].temperature < 40 %}
{% endif %}
{% else %}
{% endif %}
You have to have the above defined in printer.cfg - [temperature_sensor raspberry_pi]. claudermilk calls it "pi_4_mcu". Use what ever name you defined it as - in my case raspberry_pi.
I could not get "controller_fan" to work although it was previously defined in my config file. I don't know why, I may still be missing something.
I had to create a [fan_generic] fan section. I called it cpu_fans to avoid any confusion with controller_fan. Lastly I had to add a [duplicate_pin_override] section for the controller fans otherwise Klipper didn't like having the pin# defined more than one section. I'm not sure if this a smart thing to do but it was the only way to get it to work. If I doing something wrong, let me know. I would still like to know why the controller_fan reference does not work.
claudermilk
I should have stipulated that. The fan has to be defined as fan_generic. I now recall I tried to make it work as a controller_fan and it wouldn't; I'd also like to know why. It's some quirk of how Klipper defines them, but I have no idea what it does different between generic and controller fans. I only have the generic pin definition in my config files.
@Yezariael yes, this goes into your printer.cfg file.
VoronAT
:) When you say generic pin, do you mean generic fan? Did you have to add a [duplicate_pin_override] section in your file? Without it, Klipper doesn't like the pin being defined in more than one section. If you didn't, how did you define the pin in [generic_fan]? Thanks.
claudermilk
I did not have to add a duplicate_pin_override. It sounds like you have that pin defined somewhere else. I just altered the default fan definition:
Python:
[fan_generic controller_fan]
#  Controller fan - FAN2
#  Generic so it can be controlled via delayed_gcode
pin: PD12
max_power: 1.0
kick_start_time: 0.5
120decibell
Administrator
Staff member
Moderator
Voron Owner
I went the simple route - I used the controller_fan option. Whenever the controllers are alive and holding motors, the fans run. When the controller is timed out and the motors are inactive, the fans do not run. Shutdown speed is set to full in case there is a problem.
[controller_fan controller_fan]
pin: z:P2.4
shutdown_speed: 1.0
cycle_time: 0.04
fan_speed: 0.4
idle_speed: 0.4
VoronAT
Python:
pin: PD12
max_power: 1.0
I will check the printer.cfg file when I get a chance. If I recall I did have the pin previously defined but I'm not sure why :unsure:. Thanks for your help and input.
VoronAT
pin: z:P2.4
shutdown_speed: 1.0
cycle_time: 0.04
fan_speed: 0.4
idle_speed: 0.4
If I understand correctly, this won't provide any cooling to the rpi during periods of inactivity. Correct or am I missing something? I'm trying to run the fans even when everything is inactive to provide cooling to the rpi. Thanks.
qvD
Klipper has support for temperature_fan. This associates a specific fan with a temperature sensor and controls it similar to the way the hotend fan is controlled (either using a watermark or a pid controller). I'm using this to enable either side of my skirt fans based on the Raspberry Pi / Octopus temperature using the following:
[temperature_fan Pi]
pin: PD12
off_below: 0.1
max_power: 0.5
shutdown_speed: 0
min_speed: 0
min_temp: 0
max_temp: 85
target_temp: 55
control: pid
pid_kp: 1.0
pid_ki: 0.5
pid_kd: 2.0
[temperature_fan Octopus]
pin: PD13
sensor_type: temperature_mcu
off_below: 0.1
max_power: 0.5
min_speed: 0
shutdown_speed: 0
min_temp: 0
max_temp: 85
target_temp: 55
control: pid
pid_kp: 1.0
pid_ki: 0.5
pid_kd: 2.0
I didn't really tune the pid controller, but this appears to work good enough for me.
120decibell
Administrator
Staff member
Moderator
Voron Owner
Then don’t use my option. I find the Pi doesn’t generate enough heat when the printer is idle to need cooling, but that’s my opinion.
shiftingtech
Staff member
Moderator
Voron Owner
In my opinion, your bigger risk is that the pi doesn't heat enough to turn on the fans, and your step sticks then don't get cooled during a print. Which, unfortunately is a scenario that's far more likely to do actual damage
claudermilk
In my setup I have the printer override my auto cooling cycle & just turn the fans on full in print_start, then restart the cycle again in print_end. The Octopus sits at about 41-42C when idle. The Pi will climb to over 50C since it's never truly idle, so I set up that cycle.
In print_start near the beginning:
UPDATE_DELAYED_GCODE ID=skirt_fan DURATION=0
In print_end near the end:
