Fysetc mini 12864 v2.1 button problem
JCSmart
Voron 2.4 R2 - Spider v2.3 - Mainsail
Afterburner
Good morning,
It's good that you exist.
My Voron 2.4 runs and does everything it should. (nearly)
Unfortunately there is a problem with the display. I've done everything as described and it works, but I can only access the menus and sub-menus, but I can't execute any commands there. If I confirm one by pressing the button, it doesn't do that or the set values are set to zero. Do you have an idea ahead? I am grateful for every helpful suggestion.
Voron 2.4 R2 - Spider v2.3 - Mainsail - Display fysetc mini 12864 v2.1
Greetings to all
