Question Heater extruder not heating at expected rate,why?
An error occurred when printing the model today.
This is the klippy.log that I found.
What's the reason for this?
Thanks.
(It seems that this error occurs approximately every one and a half hours.)
I just checked the wires and the connectors.
Opened the hot end and gave it a clean.
But couldn't find anything wrong.
It seems that the klippy.log file couldn't be uploaded. There is a section of this issue.
Loaded MCU 'mcu' 144 commands (v0.13.0-156-gc01e6eee1 / gcc: (15:9-2019-q4-0ubuntu1) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599] binutils: (2.34-4ubuntu1+13ubuntu1) 2.34)
MCU 'mcu' config: ADC_MAX=4095 BUS_PINS_i2c1=PB6,PB7 BUS_PINS_i2c1a=PB8,PB9 BUS_PINS_i2c2=PB10,PB11 BUS_PINS_i2c3=PA8,PC9 BUS_PINS_sdio=PC12,PD2,PC8,PC9,PC10,PC11 BUS_PINS_spi1=PA6,PA7,PA5 BUS_PINS_spi1a=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi2a=PC2,PC3,PB10 BUS_PINS_spi3=PB4,PB5,PB3 BUS_PINS_spi3a=PC11,PC12,PC10 BUS_PINS_spi4=PE13,PE14,PE12 CLOCK_FREQ=180000000 MCU=stm32f446xx PWM_MAX=257 RESERVE_PINS_USB=PA11,PA12 RESERVE_PINS_crystal=PH0,PH1 STATS_SUMSQ_BASE=256 STEPPER_OPTIMIZED_EDGE=23 STEPPER_STEP_BOTH_EDGE=1
Configured MCU 'mcu' (1024 moves)
Args: ['/home/orangepi/klipper/klippy/klippy.py', '/home/orangepi/printer_data/config/printer.cfg', '-I', '/home/orangepi/printer_data/comms/klippy.serial', '-l', '/home/orangepi/printer_data/logs/klippy.log', '-a', '/home/orangepi/printer_data/comms/klippy.sock']
Git version: 'v0.13.0-252-g68b67a16d-dirty'
Untracked files: klippy/extras/led_effect.py
Branch: master
Remote: origin
Tracked URL: https://github.com/Klipper3d/klipper
CPU: 4 core ?
Python: '3.8.10 (default, Mar 18 2025, 20:04:55) \n[GCC 9.4.0]'
Could be a broken wire in the loom. To test heat it up and move the gantry all around the perimeter to see if it cuts out.
Run a PID tune on the machine.
Sorry, my English is not very good.
What you mean is: There's a break somewhere in the wire at the hot end (the thermistor or heating block)?
Your test is to heat the hot end and then move the print head by hand to see if it will stop?
I executed the command: PID_CALIBRATE HEATER=extruder TARGET=20
No errors.
My trident hasn't been used for about half a year (it was fine before).
Today, when I opened it, it printed out a voron cube without any errors.
After creating a model of mine, this error occurred.
thanks
What I mean is the wires going to the hotend could be broken somewhere. You need to find the break somehow.
