Hi guys, I'm in mechanical engineering so my electrical knowledge starts and stops at Ohm's law... thanks in advance for the help and patience.
Setup :
V2.4r1 with dual SKR 1.4. From an electrical POV this is a stock config.
Basic toolhead wiring (no CANbus or toolhead PCB) using proper silicone wires
Inductive probe is wired as per these instructions.
So my clone PL-08N (formbot kit, 2020) seems to have failed closed after more than two years of use. Klipper gave me a "triggered before movement" error and the probe's LED was visibly deformed and lit up all the time.
I successfully checked continuity of the 3 wires (for the signal one, only from the toolhead-side to before the BAT85 diode) and tried to wiggle them and the connector to try and detect a half-broken wire, no can do.
So I ordered a new probe, only one I could find in stock without going through Aliexpress was a genuine Omron TL-Q5MC2 2M which apparently can be used interchangeably.
When connecting it, I can get it to trigger (signal led light up) but under mainsail it say "triggered" even when the probe's LED is off.
When having no probe connected and refreshing the endstops status rapidly it alternatively reports triggered and open...
So I think something is wrong with the board or another component.
TL;DR and actual question :
Can the Bat85 diode get damaged by a failed inductive probe ? How to test this ?
Can the board pin (or something else) get damaged by a failed inductive probe ? How to test this ?
Setup :
