Durahl
Soo... I've been using the Chaotic Lab CNC TAP in combination with a 0.40mm Nozzle in my System for a few months without issues but have recently started to dabble in the use of a 1.0mm Nozzle which is a whole can of worms by itself but one which also introduces a particular problem when going with TAP in general... That of 1.0mm thick and "cold" Filament still stuck to a leaky Nozzle during Probing throwing off any and all Nozzle Z-Height Calibrations
The obvious solution is to clean the Nozzle before doing the probing but there goes the Automation which I'm kinda particular on
It would also mean having to raise the Nozzle Temperature to like at least 240°C, clean it, lower it to TAP temperature, probe it, raise it again to like 250-260°C Print Temperature - argh!
The other solution would be to simply raise the Nozzle Temperature well into the softening point of the Material ( ASA in my particular case ) for the actual Probing, but this goes against the recommendation due to it damaging the Print Surfaces... Question though... Does this still apply to the ones like the LDO Powder Coated PEI Springsteel Sheets which I use? I remember reading it primarily applying to Smooth PEI Sheets
So, yea... How does everyone else solve a problem like this?
