Question Inverted TAP result
zoldemberg
Hi,
I have a Voron 2.4 R2 with Octopus PRO (446) with an optical sensor. TAP is 24V using. The TAP is connected to EBB SB2209 CAN V1.0 (RP2040). The results of the TAP are inverted. When the TAP is inactive, I get a trigger with the command QUERY_ENDSTOPS (RED LIGHT on the PCB TAP). When the TAP is in contact with the bed, I get an open status with the QUERY_ENDSTOPS (BLUE LIGHT on the PCB TAP). Tried to change the wire between TAP PCB and EBB (cross by design) but no luck. In the config I have "endstop_pin: probe:z_virtual_endstop #PG10 # Limit switch interface" and I cannot revert it as a standard pin with "!". Anyone can help ???
For me it looks like this under
stepper_z
endstop_pin : probe:z_virtual_endstop
and
[probe]
pin = !EBBCan:gpio22
speed: 5.0
lift_speed: 5.0
samples: 2
samples_result: median
sample_retract_dist: 3.5
samples_tolerance: 0.02
samples_tolerance_retries: 1
activate_gcode:
##Tap temp probing
{%set PROBE_TEMP = 150%}
{%set MAX_TEMP = PROBE_TEMP + 5%}
M109 S{ PROBE_TEMP }
{% else %}
{% endif %}
{% endif %}
