Issues with Biqu Microprobe v2 on Can Bus EBB SB2209 CAN (RP2040)
Amonen
I have finished my build (2.4r2 350) and all is working great, except the probe.
So far the probe is self checking on boot, responds to probe_up and probe_down, but I cant get it triggered (State is always triggered)
Board : Manta m8p v2
Probe : Biqu Microprobe v2
CanBoard : Can Bus EBB SB2209 CAN (RP2040)
Probe config
[output_pin probe_enable]
pin: EBBCan: gpio22
value: 0
[probe]
pin: ^!EBBCan: gpio21
deactivate_on_each_sample: False
x_offset: 0
y_offset: 0
z_offset: 0 # Will be overridden when you do a PROBE_CALIBRATE
speed: 5.0
activate_gcode:
PROBE_DOWN
G4 P500
deactivate_gcode:
PROBE_UP
Do I need to solder a pullUp resistor to the signal line?
Is using a Tap V2 a better alternative than trying to get the probe running?
Any help welcome
