Hi guys, rookie here...
I cant for the life of me figure out why KAMP's not working for me, neither adaptive meshing nor purging are working, i am sure there are just an error in one of the macros or .cfg's but i cant figure it out, can anyone figure this out?
Machine is a newly built LDO 2.4r2 350 size with Klicky.
Slicer (Orca) start gcode:
M104 S0 ; Stops OrcaSlicer from sending temp waits separately
M140 S0
M117
print_start EXTRUDER=[first_layer_temperature] BED=[first_layer_bed_temperature] CHAMBER=[chamber_temperature]
Printer.cfg:
# This file contains common pin mappings for the BigTreeTech Octopus V1.
# To use this config, the firmware should be compiled for the STM32F446 with a "32KiB bootloader"
# Enable "extra low-level configuration options" and select the "12MHz crystal" as clock reference
# after running "make", copy the generated "klipper/out/klipper.bin" file to a
# file named "firmware.bin" on an SD card and then restart the OctoPus with that SD card.
# See docs/Config_Reference.md for a description of parameters.
## Voron Design VORON2 250/300/350mm BigTreeTech OctoPus V1 TMC2209 UART config
## *** THINGS TO CHANGE/CHECK: ***
## MCU paths [mcu] section
## Thermistor types [extruder] and [heater_bed] sections - See https://www.klipper3d.org/Config_Reference.html#common-thermistors for common thermistor types
## Z Endstop Switch location [safe_z_home] section
## Homing end position [gcode_macro G32] section
## Z Endstop Switch offset for Z0 [stepper_z] section
## Probe points [quad_gantry_level] section
## Min & Max gantry corner postions [quad_gantry_level] section
## PID tune [extruder] and [heater_bed] sections
## Probe pin [probe] section
## Fine tune E steps [extruder] section
[mcu]
## Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_xxxxxxxxxx335331383820-if00
restart_method: command
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000 #Max 4000
max_z_velocity: 15 #Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 350
square_corner_velocity: 5.0
# Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
#[safe_z_home]
## XY Location of the Z Endstop Switch
## Update -10,-10 to the XY coordinates of your endstop pin
## (such as 157,305) after going through Z Endstop Pin
## Location Definition step.
#home_xy_position:234,356
#speed:100
#z_hop:10
#z_hop_speed:5
## Use QUAD_GANTRY_LEVEL to level a gantry.
## Min & Max gantry corners - measure from nozzle at MIN (0,0) and
## MAX (250, 250), (300,300), or (350,350) depending on your printer size
## to respective belt positions
[quad_gantry_level]
## Gantry Corners for 350mm Build
## Uncomment for 350mm build
gantry_corners:
-60,-10
410,420
## Probe points
50,25
50,275
300,275
300,25
speed: 100
horizontal_move_z: 10
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
[bed_mesh]
speed: 300
mesh_min: 40, 40
mesh_max: 310,310
zero_reference_position: 175,175 #for use with stock z endstop
#fade_start: 0.6
#fade_end: 10.0
#probe_count: 5,5 # Values should be odd, so one point is directly at bed center
#algorithm: bicubic
[include fluidd.cfg]
[include macros.cfg]
[display_status]
[pause_resume]
[exclude_object]
# This file contains all settings for KAMP, and must be included in printer.cfg with:
[include KAMP_Settings.cfg]
[include config_backup.cfg]
### The following [includes] can be uncommented from within KAMP_Settings.cfg. ###
# This file enables the use of adaptive meshing.
[include ./KAMP/Adaptive_Meshing.cfg]
# This file enables the use of adaptive line purging.
[include ./KAMP/Line_Purge.cfg]
# This file enables the use of the adaptive Voron logo purge.
[include ./KAMP/Voron_Purge.cfg]
# This file enables the use of KAMP's Smart Park feature.
#[include ./KAMP/Smart_Park.cfg]
[autotune_tmc stepper_x]
motor: ldo-42sth48-2004mah
[autotune_tmc stepper_y]
[autotune_tmc stepper_z]
motor: ldo-42sth48-2004ac
[autotune_tmc stepper_z1]
[autotune_tmc stepper_z2]
[autotune_tmc stepper_z3]
[autotune_tmc extruder]
motor: ldo-36sth20-1004ahg
# Macros
[include klicky-probe.cfg]
#[gcode_macro G32]
#gcode:
# SAVE_GCODE_STATE NAME=STATE_G32
# G90
# G28
#QUAD_GANTRY_LEVEL
#G28
#G0 X175 Y175 Z30 F3600
#RESTORE_GCODE_STATE NAME=STATE_G32
#*# <---------------------- SAVE_CONFIG ---------------------->
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 40.335
#*# pid_ki = 1.921
#*# pid_kd = 211.758
#*# [extruder]
#*# control = pid
#*# pid_kp = 34.295
#*# pid_ki = 4.314
#*# pid_kd = 68.162
#*# [stepper_z]
#*# position_endstop = -1.060
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# -0.030000, 0.045000, 0.070000, 0.038750, -0.015000
#*# -0.070000, -0.000000, 0.016250, -0.023750, -0.075000
#*# -0.066250, -0.007500, 0.000000, -0.040000, -0.085000
#*# -0.063750, -0.008750, 0.007500, -0.025000, -0.072500
#*# -0.026250, 0.030000, 0.052500, 0.022500, -0.027500
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 40.0
#*# max_x = 310.0
#*# min_y = 40.0
#*# max_y = 310.0
#*# [probe]
#*# z_offset = 5.010
M140 S0
M117
Printer.cfg:
[mcu]
[printer]
kinematics: corexy
max_velocity: 300
max_z_accel: 350
[idle_timeout]
timeout: 1800
#[safe_z_home]
#speed:100
#z_hop:10
#z_hop_speed:5
[quad_gantry_level]
gantry_corners:
-60,-10
410,420
## Probe points
50,25
50,275
300,275
300,25
speed: 100
retries: 5
max_adjust: 10
[bed_mesh]
speed: 300
mesh_min: 40, 40
mesh_max: 310,310
#fade_start: 0.6
#fade_end: 10.0
#algorithm: bicubic
[display_status]
[pause_resume]
[exclude_object]
# Macros
#[gcode_macro G32]
#gcode:
# G90
# G28
#QUAD_GANTRY_LEVEL
#G28
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 40.335
#*# pid_ki = 1.921
#*# [extruder]
#*# control = pid
#*# pid_kp = 34.295
#*# pid_ki = 4.314
#*# pid_kd = 68.162
#*# [stepper_z]
#*# version = 1
#*# points =
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 40.0
#*# max_x = 310.0
#*# min_y = 40.0
#*# max_y = 310.0
#*# [probe]
