LDO 350mm Kit bulid need help
jnaviles
LDO v2.4 Rev. C
I just completed my LDO kit and i ran to a couple of hicups. First I had it running just fine. Then for some reason the Octopus board that came with kit just wouldn't connect anymore, so I bought a new board. I put all the connecters in the same ports. Now when input G28 X both the X and Y move. I have followed the Voron design tutorial.
  • printer.txt
I figured out the problem. The X stepper motor driver failed. I switched the one from the Extruder and it worked without a problem. Went to microcenter and bought a couple of drivers.
I think it came out pretty good for a first print....
