- 2.4R2
- Galileo
Hello everyone,
I've been unhappy with the noise level of my Z motors on my Voron 2.4R2 for quite some time. But I'm stuck and hope you can help me out
I'm using Stepper Online 17HS19-2004S1 motors. The A and B motors are very quiet.
It's mainly the normal Z movements that are extremely loud. This especially bothers my wife, as the printer is in the attic directly above our bedroom.
What have I tried so far?
What else could I try? Could the motors themselves be the problem? Would switching to G2Z-XL help?
Here’s a video of the issue:
I hope someone can help me figure this out.
Thanks in advance,
ByteChild
- StealthChop – Slightly reduced the noise, but not by much.
- TMC Auto-Tune – Had almost no effect.
- Changing run_current – I tried lowering it from 0.8 to 0.6, and increasing it to 1.0, 1.2, and 1.4. Lower current made no difference; higher current made it even louder.
- Speeds – When I reduce max_z_velocity to 8, it's bearable. That’s fine for homing, but too slow for regular movement. Increasing max_z_velocity just makes it louder. I tested in 5-unit steps up to max_z_velocity: 50.
- Mainboard replacement – I switched from 2x SKR 1.4 to an LDO Leviathan 1.2. No change. Both used TMC2209 drivers for the Z axis. I don’t think the drivers are the issue, since A & B also used TMC2209s and were barely audible.
- Rebuilt the Z-drive modules – With R2, I rebuilt the Z-drives, checked all screws, and re-secured them with Loctite.
- Placed a sidewalk board and foam underneath the printer – No change.
- Switched to Panzerballs – No change.
Thanks in advance,
ByteChild
