erik.zweigle
- Voron Zero
- Extruder Type
- Orbiter
- Cooling Type
- Afterburner
Hello,
My printer stops abruptly at random times 50% to 75% through a print. I cannot recover it through the web or klipperscreen. I need to power cycle. I thought it may be overheating because I transitioned from PLA to ABS recently and the build plate being 100°C so I swapped in a rear cover with perforations and added a larger fan to allow it to ventilate. But it quit again mid-print, and this time with PLA as I was testing the changes. Attached are excerpts from the klippy.log & moonraker.log files. I'm not sure how to read them but I think mcu timeout means a loose cable from umbilical PCB to Raspi4? Has anybody else had a similar problem?
Extruder max_extrude_ratio=2.078758
mcu 'mcu': Starting serial connect
webhooks client 4128911408: New connection
webhooks client 4128911408: Client info {'program': 'Moonraker', 'version': 'v0.9.3-0-g71f9e67'}
mcu 'mcu': Timeout on connect
mcu 'mcu': Wait for identify_response
Traceback (most recent call last):
File "/home/voron/klipper/klippy/serialhdl.py", line 68, in _get_identify_data
params = self.send_with_response(msg, 'identify_response')
File "/home/voron/klipper/klippy/serialhdl.py", line 262, in send_with_response
return src.get_response([cmd], self.default_cmd_queue)
File "/home/voron/klipper/klippy/serialhdl.py", line 319, in get_response
self.serial.raw_send_wait_ack(cmds[-1], minclock, reqclock,
File "/home/voron/klipper/klippy/serialhdl.py", line 254, in raw_send_wait_ack
self._error("Serial connection closed")
File "/home/voron/klipper/klippy/serialhdl.py", line 61, in _error
raise error(self.warn_prefix + (msg % params))
serialhdl.error: mcu 'mcu': Serial connection closed
