- Voron 0.2 mixed with Voron 0.1
- Galileo
- Other
Hello everyone,
I could use your help. I can't see the wood for the trees.
I'm currently building a formbotkit of a Voron 0.2 and am in the process of setting up the printer.cfg. Unfortunately I have some problems with the sensorless homing.
I think this is because I have built a wild mixture of a 0.1 and a 0.2. Specifically I mean I have used CNC parts which are actually meant for a 0.1. That means I don't have the Z-Home switch at the bottom of the Z-axis but at the top.
I can actually home Z quite well. I have simply entered -0.10 for "position_endstop" as in the Voron 0.1 sample configuration.
My problem now is that the X and Y axes cannot be homed correctly with sensorless homing. The axes move a bit and then think they are homed. At the same time, Z keeps moving down a bit.
I'm really stumped right now and can't figure out what's wrong. A nudge in the right direction would be great.
Thank you very much.
Greetings
Joe
Greetings
Joe
