- Voron 2.4 350x350, Formbot Kit, Octopus, raspberry pi 4 2gig
- Other
I just finished building my new 350x350 Voron 2.4 with a raspberry pi 4 2gig, octopus board, I managed to test all motors and successfully homed X and Y. However when I try to home my Z axis the gantry goes up by 10 and give following error message Move out of range: -10.000 -10.000 10.000 [0.000].
tks
Francois
# Z Stepper Settings
## Z0 Stepper - Front Left
## Connected to MOTOR_2
## Endstop connected to DIAG_2
[stepper_z]
step_pin: PF11
dir_pin: !PG3
enable_pin: !PG5
rotation_distance: 40
gear_ratio: 80:16
microsteps: 32
endstop_pin: PG10
## Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
## (+) value = endstop above Z0, (-) value = endstop below
## Increasing position_endstop brings nozzle closer to the bed
## After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
position_endstop: -0.5
## Uncomment below for 250mm build
#position_max: 210
## Uncomment below for 300mm build
#position_max: 260
## Uncomment below for 350mm build
position_max: 310
position_min: -5
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
## Z1 Stepper - Rear Left
## Connected to MOTOR_3
[stepper_z1]
step_pin: PG4
dir_pin: PC1
enable_pin: !PA0
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z1]
uart_pin: PC7
interpolate: false
run_current: 0.8
## Z2 Stepper - Rear Right
## Connected to MOTOR_4
[stepper_z2]
step_pin: PF9
dir_pin: !PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z2]
uart_pin: PF2
interpolate: false
run_current: 0.8
## Z3 Stepper - Front Right
## Connected to MOTOR_5
[stepper_z3]
step_pin: PC13
dir_pin: PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z3]
uart_pin: PE4
interpolate: false
run_current: 0.8
tks
Francois
[stepper_z]
step_pin: PF11
dir_pin: !PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
endstop_pin: PG10
#position_max: 210
#position_max: 260
position_max: 310
position_min: -5
homing_speed: 8
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
[stepper_z1]
step_pin: PG4
dir_pin: PC1
enable_pin: !PA0
gear_ratio: 80:16
microsteps: 32
uart_pin: PC7
interpolate: false
run_current: 0.8
[stepper_z2]
step_pin: PF9
dir_pin: !PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
uart_pin: PF2
interpolate: false
run_current: 0.8
[stepper_z3]
step_pin: PC13
dir_pin: PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
uart_pin: PE4
interpolate: false
run_current: 0.8
