Iceman_Pol
I'm new to Core XY and I built a Voron Trident. Not from a kit but sourced all the parts myself.
I'm using a PI 4, fysetc spider 3.0 connected by usb to can, ebb sb2209 (rp2040) CAN and a btt eddy using can via the sb2209.
Im having issues printing. I've managed to print a flat sheet. So I thought the next thing was to calibrate X and Y. So I printed a 20mm cube.
Just the back left and front right corners (from above) are skewed. The other 2 corners a perfect.
I've deracked (without belts), set the tension to so that there is no racking caused by the belt tension. With the printer off and pushing the gantry there is a little left to right movement of the head.
How do I get rid of this movement and how do I fix this print issue?
