- 2.4r2 350mm
- Clockwork 2
Hello!
I'm currently having an issue where my probes are trending upwards. It's relatively minor, but I just can't figure out what could be causing it. Over ~100 samples, it increases by about 0.02mm. Over 10 probes, I get a sample standard deviation of ~0.005mm, which seems pretty good (albeit out-of-spec). In general, I can start a print and get very good results, but I have to baby it through my
The voron docs (Probe Accuracy Check) mentions "Make sure that the sensed distance is not trending (gradually decreasing or increasing over the 10 probes) and that the standard deviation is less than 0.003mm." but it doesn't actually say what to do if you're trending in one direction.
I'm currently running a 2.4r2 350mm, Stealthburner (with the AB X-axis mount because I was too lazy to swap it out when SB came out and I found that M3 nuts press fit nicely into the back of that mount which made it compatible), and a Euclid probe. LDO steppers for Z-axis. 1.1 A run current,
I've been running my 2.4r2 for about 18 months now, and probing has always been an issue. I built before SB (and therefore tap), initially with the Omron inductive probe. That worked really well, but eventually the probe failed after about 6 months. Fortunately, I had anticipated it, and printed a Klicky. I never got consistent results with Klicky, and realized it was that the wires weren't making good contact with the magnets for conduction, but I couldn't get that to work--so I sidestepped it by switching to Euclid and have had pretty good results ever since. BUT, I'm noticing the problem seems to be getting worse, so I want to try to figure it out while my only printer is still working.
Any help would be appreciated!
print_start
macro because of the probing, which fails about 1 in 5 times. And by baby, I just mean restart the print until it works.The voron docs (Probe Accuracy Check) mentions "Make sure that the sensed distance is not trending (gradually decreasing or increasing over the 10 probes) and that the standard deviation is less than 0.003mm." but it doesn't actually say what to do if you're trending in one direction.
stealthchop_threshold
= 9999 (on). I've been running my 2.4r2 for about 18 months now, and probing has always been an issue. I built before SB (and therefore tap), initially with the Omron inductive probe. That worked really well, but eventually the probe failed after about 6 months. Fortunately, I had anticipated it, and printed a Klicky. I never got consistent results with Klicky, and realized it was that the wires weren't making good contact with the magnets for conduction, but I couldn't get that to work--so I sidestepped it by switching to Euclid and have had pretty good results ever since. BUT, I'm noticing the problem seems to be getting worse, so I want to try to figure it out while my only printer is still working.
