Coyote
I assembled and installed the first two z-drives with no issue. But when I started assembling the belt drive for the third z-drive that is when the proverbial shit hit the fan. None of the 625 bearings would fit onto the shaft. Measuring the shaft yielded a value of 4.9mm while the inside diameter of all my 625 bearing was 4.80-4.81 mm. Has anyone else had this problem? I suppose I could grind or use emery cloth to make it fit but I'm unsure of the final results. Any comments or suggestions
