Problem flashing picobilical on LDO 0.2-S1 kit?
norainu
Hi I'm almost finished building my first Voron (LDO v0.2-S1 kit), assembly was fairly smooth but I'm having trouble flashing my Picobilical board. No matter how many times I upload the klipper.uf2 file to the board, it restarts in bootloader mode and I can't get it to be recognized as a USB serial device. I've successfully flashed the SKR pico using the same uf2 file so I think the file itself is fine.
Has anyone run into the same problem?
Did you also ask about this on discord?
We helped (tried to help, at least) someone there yesterday, but could not find any way to get the board to flash properly, with the conclusion that they may have had a bad flash chip.
Ah sorry yes you guys helped me on discord, thanks! I talked to LDO support, they think the board could be faulty and they're sending me a new board. I should have asked to close this thread, sorry for the inconvenience!
Hi in case anyone is having similar issues, I received a new board from LDO today and it flashed without problems.
