Sensorless homing - tuning the stallguard value
drpeej
My first attempt at sensorless homing a couple of years ago was a failure as I just couldnt get it to work.
Due to a stupid mistake on my part, I have recently had to reinstall clipper and rebuild my configuration.
I decided to try sensorless again using https://docs.vorondesign.com/tuning/sensorless.html. This time it worked first time and was so straightforward that I dont know what went wrong first time.
I am puzzled about how to adjust the stallguard value. Following the instructions, the MAX value was easy enough to find. However I am not sure how to find the minimum value. I reduced the value and reached a point where I could hear the carriage hit the limit. However it was really vague and not as obvious as finding the MAX value. I have chose a MIN value 30 less than the MAX so my stall guard value is 15 which seems to work. Does this sound about right? It all seems to be working well.
The instructions suggest finding a MAX value and a MIN value of driver_SGTHRS where the virtual endstop is triggered and then you set the final value at the midpoint. I guess its no too important if it works
Yeah, I got mine tuned just enough to be repeatable, but still need to fine tune it. I figured it's good enough for now, and stopped chasing that particular unicorn for the time being...but I'll be back at it again one day. Once I finish these other printers.
Keep at it, but don't pull your hair out. If it is homing fine...it is homing fine.
I recently had to switch my Trident over to sensorless (X switch finally died). I just followed the instructions on t he Voron docs site. The only setting I had to tweak was driver_SGTHRS. I have no min, max, or stallguard set. Just tweaked the mentioned setting until I got a good repeatable stop without slamming & left it at that. It really was surprisingly easy.
So, as @5twenty said: if it's working then it's working.
