Hi All,
its probably a silly question, but need to ask, I finished my build last weekend and printed the voron cube, looks good, altough 1st layer did not go as I was expecting any way, yesterday I turned on the printer received a call that lasted probably 20 minutes, and when I came back, I noticed that my mainsail was telling me no comunication with the controller, and probably a Firmware reset will fix the issue, I tried that several times, switched the printer on and off several times, I even turned off the printer for like 5 minutes and turned back on, still no communication, so I went to bed thinking probably my Spider V3 got damaged somehow while I was away on a call and thinking on replacing it with a BTT octupus V1.1, so today I woke up and before coming to work I switched it on, and worked, not sure how but it works, does any one have any suggestions on how to avoid this issue? a heatsink probably? a loose cable perhaps?
Thanks any suggestion would be appreciated.
