Ho-whizzle
hello and apologies for the silly question but it has been a while since I changed klipper so i am rusty.
I have erased and flashed a new klipper from scratch and every is good except the strange start up sequence when it start a print. The current sequenceis as follows PLA:
- Heats bed to 60 degree
- Heats nozzle to 220 degree
- Homes X and Y then move to center
- Message Ëxtruder temperature target of 220 degree is too high, lowering to 150 degree
- Nozzle temp lows to 150 degree then homes Z
- Z-tilt (Because it is a trident)
- Homes Z again
- Soaks for 5mins
- Heats nozzle to 150 degrees again
- Does adaptive mesh
- Starts print
- Print completed, BUT the print head remains in the last position above the print and DOES NOT move back away from it.
So my questions are as followings:
1. How can I ask the printer NOT to heat the nozzle to 220 before homing XY and Z?
2. Can I adjust the soak time to be short or longer?
3. How can I ask the printer to move back to XY home position after the print ?
4. Can I ask the filament to retract a bit to avoid filament leaking out ?
Klipper file is attached.
- Homes Z again
- Soaks for 5mins
- Starts print
