Starting point for used partially complete 2.4
RichT
Bought a partially completed 2.4 that turns on. Home all moves the printhead to the back corner maybe an inch up but the quad corner level just moves to the front left and stops.
How do I know what I have? I know there's a raspberry pi and a bigtreetech octopus board. Can I plug a monitor and keyboard into the rpi and see what versions and software are there?
Thanks!
You could connect a ethernet cable to the pi, then access the web interface.
Though I would think about just starting from scratch with the pi and klipper. Who knows what's on there. Flash is with a fresh install of MainsailOS, or RatOS, or rasbian if you want to do everything yourself.
I would go through the Voron build and check all the things you think it might need or be beneficial to you. Most likely you will need to go through the config and setup portion.
