Hello everyone, brand new to the site so apologies ahead of time if I'm asking something I should have been able to find on my own. I have a V2.4 300mm with a Phaetus Rapido HF extruder. It works fantastic with one exception, because the fan ducts that are aimed at the nozzle are located towards the front half of the nozzle- the back half naturally gets less cooling. Where this becomes an issue for me is when I attempt to print threads, for example a large bolt. What occurs is a slight up curl on the tips of the threads where there is less cooling, when using certain filaments.
So hence my quest, I was hoping someone may have a set of .step files that would allow me to relocate the ducts slightly further back to provide a little more even cooling around the nozzle. I did locate the printable .stl files on the website but unfortunately no matter what I try I can not format the files so they are workable with my Solidworks. Also, if I do manage to get a workable file and I am happy with the mods, is this something others would have an interest in? Please let me know and I'll be happy to post the results for others to use.
Cheers and many thanks in advance for anyone able to help.
