- Voron 2.4R2 350mm
- Clockwork 2
Hi,
I have finished building and am currently tunning a Voron 2.4 350mm kit from Siboor. The printer successfully prints, and I have managed to get it well tuned but have one remaining vexing issue. At the initial flip of the power switch one of the stepper motors begins to vibrate like it is being randomly signaled, as soon as the system is fully booted the vibration goes away and the printer performs as expected. I am concerned with damaging a motor during startup. The issue seems isolated to the B motor.
Video of behvior:
I have tried a couple of things to narrow down the issue:
1. Swapped driver modules - no change
2. Removed driver from B motor - no vibration on startup
3. Added driver back in, swapped A and B motors - vibration now on A motor indicating potential issue with FYSTEC Spyder 2.3 board channel M0
So with this testing I think I have narrowed the issue to the channel on the controller board. Does anyone have some suggestions where to go from here? The configuration is the same between the A and B motor sections.
Thanks
Video of behvior:
Thanks
