Tearing my hair our trying to flash Klipper
drpeej
I have spent 2 days trying to get Klipper to work
I keep getting this
I have checked and double checked everything and done a clean installation twice
When I run ls /dev/serial/by-id I get this
pi@mainsailos:~ $ ls /dev/serial/by-id
usb-Klipper_stm32f446xx_1F000A000550314D35323820-if00
pi@mainsailos
The start of my printer.cfg file is like this
[include mainsail.cfg]
[mcu]
# run ls /dev/serial/by-id/ in ssh terminal to get the controller name
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_1F000A000550314D35323820-if00
I attach my moonraker log
I can't think of anything else to try
Can anyone advise please?
Peter
The error message is about the [mcu rpi] section in printer.cfg, it's not about the main [mcu] section.
The [mcu rpi] section refers to using the Raspberry Pi as an extra mcu, and connect stuff like a vibration sensor and maybe other things as well.
The [mcu] section refers to the primary mcu, such an Octopus or similar.
Your printer.cfg has an [mcu rpi] section but klipper can't find the configured comm socket "/tmp/klipper_host_mcu".
It's probably because the "klipper linux mcu Service" is not running.
I don't know if you are going to use the Raspberry Pi as an extra mcu, or if that section was just included in printer.cfg by default when klipper was installed.
In any case, you can comment out a couple of lines in printer.cfg and with a little luck get things going again.
Then, if you need an [mcu rpi] section for use with an [adxl345] and an [input_shaper] section, you can troubleshoot the "klipper linux mcu Service" later.
Or just leave the lines commented out if you don't need them.
Comment out these lines in printer.cfg, make them look like this:
#[mcu rpi]
#serial = /tmp/klipper_host_mcu
#[adxl345]
#cs_pin = rpi:None
#[resonance_tester]
#accel_chip = adxl345
#probe_points =
#        175, 175, 20
For reference, this is from the attached klippy-6.log:
mcu 'rpi': Starting connect
mcu 'rpi': Unable to open port: [Errno 2] No such file or directory: '/tmp/klipper_host_mcu'
More about using Raspberry Pi as an extra mcu: https://www.klipper3d.org/RPi_microcontroller.html
#[mcu rpi]
#[adxl345]
#cs_pin = rpi:None
#[resonance_tester]
#probe_points =
#        175, 175, 20
Thanks, thats really helpful. Its also similar to the advice I was given by the person I bought the kit from.
Unforunately I have had to retire to my bed feeling unwell so I cant check it out till tomorrow when I hope ill be feeling better
Peter
