H3DA
Hi everyone,
I’m having trouble with temperature readings on a newly assembled Voron 2.4 350mm equipped with an BTT Octopus V1.1 board. I’m using a 10k B3950 NTC thermistor to measure the chamber temperature, but Klipper is showing incorrect readings (for example, 80°C instead of 20°C at room temperature).
I've already tried two new thermistors, and I’m still getting the same incorrect readings, so it doesn't seem to be a sensor issue. My current configuration in printer.cfg is as follows:
[temperature_sensor chamber_temp]
sensor_type: Generic 3950
sensor_pin: PF5
min_temp: 0
max_temp: 100
gcode_id: chamber_th
For reference, I also have a Voron 2.4 300mm and a Trident 250mm, both working without issues. Has anyone experienced a similar issue or knows how to fix these readings on an Octopus V1.1?
Any advice would be greatly appreciated!
sensor_pin: PF5
min_temp: 0
max_temp: 100
