Been printing away on my trident for some time now and a friend asked me if I could look at a small print job for them - no problem. Everything is running well, the only thing I'm unhappy with is what appears to be a low spot on the bed, but I can work around that. Started printing out parts, but now I'm in a rush to get the parts off the bed. Ah ha! It's a steel sheet held down by a magnet, I can pop it off, pop the part off, put the sheet back in place and start the run again!
Yeah - turns out that when you don't remove the protective plastic film over the smooth side, it shrinks with the heat, ruffles up and gives you terrible bed meshes that can move around.
So I've had to redo my Z-offset, but I'm getting a beautiful first layer now!
